Ana içeriğe geç
Jabra Elite 85h Speaker Replacement
Neye ihtiyacın var
  1. Jabra Elite 85h Speaker Replacement, Ear Cushion: adım 1, 3 resimden 1. Jabra Elite 85h Speaker Replacement, Ear Cushion: adım 1, 3 resimden 2. Jabra Elite 85h Speaker Replacement, Ear Cushion: adım 1, 3 resimden 3.
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Speaker Replacement, Speaker: adım 2, 3 resimden 1. Jabra Elite 85h Speaker Replacement, Speaker: adım 2, 3 resimden 2. Jabra Elite 85h Speaker Replacement, Speaker: adım 2, 3 resimden 3.
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Speaker Replacement: adım 3, 3 resimden 1. Jabra Elite 85h Speaker Replacement: adım 3, 3 resimden 2. Jabra Elite 85h Speaker Replacement: adım 3, 3 resimden 3.
    • Repeat the previous steps for the other side, removing the foam inserts with care.
  4. Jabra Elite 85h Speaker Replacement: adım 4, 1 resimden 1.
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Speaker Replacement: adım 5, 1 resimden 1.
    • Repeat the previous step for the other side, removing the four T6 screws.
  6. Jabra Elite 85h Speaker Replacement: adım 6, 1 resimden 1.
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matt Gardiner
324 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Petersen Spring 2023 UMass Dartmouth, Team 3-4, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G4
4 Üyeler
9 adet Kılavuz yazıldı
3 Yorum
Thanks a lot man, I was having some issues with my left side for a while. I assumed it was bad connection since it would return depending on the position and sometimes on non-ANC setup. I just tightened those screws and now it works fine. Cheers.
Alex Fernandes - Yanıt
Hi, doughter overturned the speaker. Now the device no longer switches on. can this be fixed again?
Thanks fit your Help.
Regards
Oliver Viboh - Yanıt
Where can I get replacement speakers. I know it is 40mm in diameter but what is the ohm and other specifications?
Çağdaş Son - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 92
Her zaman: 937
