Ana içeriğe geç
Jabra Evolve2 65 Battery Replacement
Neye ihtiyacın var
    1. Jabra Evolve2 65 Battery Replacement, Ear Pads: adım 1, 1 resimden 1.
      • Lay your headphones down on a flat, solid surface.
      FixBot'a Sor
      Yorum Ekle
    2. Jabra Evolve2 65 Battery Replacement: adım 2, 2 resimden 1. Jabra Evolve2 65 Battery Replacement: adım 2, 2 resimden 2.
      • Insert an opening tool into the seam between the ear pad and driver housing, near the hinge.
      • Gently pry the ear pad away from the driver housing until it releases.
      FixBot'a Sor
      Yorum Ekle
    3. Jabra Evolve2 65 Battery Replacement: adım 3, 2 resimden 1. Jabra Evolve2 65 Battery Replacement: adım 3, 2 resimden 2.
      • Pry off the other ear pad in the same manner.
      FixBot'a Sor
      Yorum Ekle
    1. Jabra Evolve2 65 Battery Replacement, Motherboard: adım 4, 2 resimden 1. Jabra Evolve2 65 Battery Replacement, Motherboard: adım 4, 2 resimden 2.
      • Peel back the tape where the microphone's base connects to the headband.
      • Use a T6 Torx screwdriver to remove the single 2 mm screw.
      FixBot'a Sor
      Yorum Ekle
    2. Jabra Evolve2 65 Battery Replacement: adım 5, 1 resimden 1.
      • Go about a third of the way around the first screw and peel back the tape to locate the second screw.
      • Use T6 Torx screwdriver to remove the single 2 mm screw.
      FixBot'a Sor
      Yorum Ekle
    3. Jabra Evolve2 65 Battery Replacement: adım 6, 1 resimden 1.
      • Locate the third screw after peeling the tape off entirely after removing the second screw.
      • Use a T6 Torx screwdriver to remove the final 2 mm screw.
      FixBot'a Sor
      Yorum Ekle
    4. Jabra Evolve2 65 Battery Replacement: adım 7, 3 resimden 1. Jabra Evolve2 65 Battery Replacement: adım 7, 3 resimden 2. Jabra Evolve2 65 Battery Replacement: adım 7, 3 resimden 3.
      • Use an opening tool to pry up and set aside the driver housing.
      • Gently remove the motherboard from the housing..
      FixBot'a Sor
      Yorum Ekle
    5. Jabra Evolve2 65 Battery Replacement: adım 8, 3 resimden 1. Jabra Evolve2 65 Battery Replacement: adım 8, 3 resimden 2. Jabra Evolve2 65 Battery Replacement: adım 8, 3 resimden 3.
      • After locating the battery underneath, use a pair of tweezers to disconnect all connected cables.
      • Using tweezers, gently wiggle out the connector that joins the battery to the motherboard. The correct connector will be labeled on the motherboard and is the one that contains 2 wires, one black and one red.
      FixBot'a Sor
      Yorum Ekle
    6. Jabra Evolve2 65 Battery Replacement: adım 9, 1 resimden 1.
      • Using a soldering iron, desolder the driver connections from the motherboard.
      • When reinstalling the driver to the motherboard, make sure you solder the driver connections to the correct terminals. The red wire goes to the "P" and the black wire goes to the "N."
      FixBot'a Sor
      Yorum Ekle
    1. Jabra Evolve2 65 Battery Replacement, Battery: adım 10, 3 resimden 1. Jabra Evolve2 65 Battery Replacement, Battery: adım 10, 3 resimden 2. Jabra Evolve2 65 Battery Replacement, Battery: adım 10, 3 resimden 3.
      • Using an opening tool, gently pry out the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
JPittsley
218 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Botvin Spring 2025 UMass Dartmouth, Team 3-2, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S3G2
4 Üyeler
35 adet Kılavuz yazıldı
1Rehber Yorum
How do I get the battery replacement
KAMUGISHA ALLAN - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 66
Son 30 gün: 302
Her zaman: 2,577
