Ana içeriğe geç
Giriş
In order to access the inner components of the Jabra Speak 510, you will need to remove the back plate and the front plate.
Parçalar
Hiçbir parça belirtilmedi.
  1. Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws. Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Remove the six 20 mm T6 screws from the bottom of the device.
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Remove the back plate and the grey foam underneath. Remove the back plate and the grey foam underneath.
    • Remove the back plate and the grey foam underneath.
  4. Use a small, pointed metal spudger to  release the plastic tabs connecting the faceplate to the bottom of the speaker. A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening  the device. Slowly flip the device open like a clam shell.
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
Sonuç
Jordan Murphy
594 İtibar
3 adet Kılavuz yazıldı
Takım
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 83
