Giriş
Original from https://www.electronicslovers.com/2015/0...
Hello Electronic Lovers, in this tutorial I will show you how to repair a broken Power port of the JADOO box. You can Replace a Power Port or by connecting charger wires directly to the main circuit. We need 5v DC output from the charger or power supply to run JADOO box. I will recommend to change a Port instead of connecting wires directly.
Neye ihtiyacın var
The box back cover doesn’t not has screw, just use any sharp thing, knife, in the edge of the box and pull the sharp thing , knife, a cover will be popped up and take out The circuit Board carefully.
