Ana içeriğe geç
Jam Voice Speaker Replacement
Neye ihtiyacın var
  1. Jam Voice Speaker Replacement, Hard Mesh Cover: adım 1, 2 resimden 1. Jam Voice Speaker Replacement, Hard Mesh Cover: adım 1, 2 resimden 2.
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
    FixBot'a Sor
    Yorum Ekle
  2. Jam Voice Speaker Replacement, Motherboard: adım 2, 1 resimden 1.
    • Remove the four 7mm Phillips screws from the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  3. Jam Voice Speaker Replacement: adım 3, 2 resimden 1. Jam Voice Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  4. Jam Voice Speaker Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
    FixBot'a Sor
    Yorum Ekle
  5. Jam Voice Speaker Replacement: adım 5, 3 resimden 1. Jam Voice Speaker Replacement: adım 5, 3 resimden 2. Jam Voice Speaker Replacement: adım 5, 3 resimden 3.
    • Remove the four 7mm Phillips screws to expose the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Jam Voice Speaker Replacement: adım 6, 1 resimden 1.
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
    FixBot'a Sor
    Yorum Ekle
  7. Jam Voice Speaker Replacement: adım 7, 2 resimden 1. Jam Voice Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
    FixBot'a Sor
    Yorum Ekle
  8. Jam Voice Speaker Replacement, Speaker: adım 8, 1 resimden 1.
    • Use tweezers to pull out the speaker's wire from the motherboard.
    • Use tweezers to pull out the battery's wire from the motherboard.
    • The speaker's connection point is opposite the battery's connection point.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Buck
358 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 915
