Ana içeriğe geç
Jazz UltraTab C1059-HL Antenna Replacement
Neye ihtiyacın var
  1. Jazz UltraTab C1059-HL Antenna Replacement, Antenna: adım 1, 1 resimden 1.
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Antenna Replacement: adım 2, 1 resimden 1.
    • Remove the back panel of the device.
  3. Jazz UltraTab C1059-HL Antenna Replacement: adım 3, 1 resimden 1.
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Antenna Replacement: adım 4, 1 resimden 1.
    • Identify the antenna cover on the top of the device.
  5. Jazz UltraTab C1059-HL Antenna Replacement: adım 5, 1 resimden 1.
    • Remove the two screws holding the antenna cover in place.
  6. Jazz UltraTab C1059-HL Antenna Replacement: adım 6, 1 resimden 1.
    • Use a prying tool to remove the plastic piece off of the antenna component.
  7. Jazz UltraTab C1059-HL Antenna Replacement: adım 7, 1 resimden 1.
    • Identify the antenna component as the gray cable that comes out of the plastic cover.
  8. Jazz UltraTab C1059-HL Antenna Replacement: adım 8, 1 resimden 1.
    • Remove all of the adhesive tape pieces off of the antenna cable.
  9. Jazz UltraTab C1059-HL Antenna Replacement: adım 9, 1 resimden 1.
    • Once all of the adhesive tape has been removed. Pull out the antenna component.
  10. Jazz UltraTab C1059-HL Antenna Replacement: adım 10, 1 resimden 1.
    • The antenna will be attached to the chip in your device. Be careful not to pull off.
    • Solder of the wire that is connected to the chip in order to be able to remove the antenna component.
    • Once this is done, you can replace your old antenna with a new one!
Sonuç
Amanda Justiniano
231 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 üyesi
IUPUI-WILSON-F15S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 224
