Ana içeriğe geç
Jazz UltraTab C1059-HL Battery Replacement
Neye ihtiyacın var
    1. Jazz UltraTab C1059-HL Battery Replacement, Battery: adım 1, 1 resimden 1.
      • remove the screws at the four corners of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Jazz UltraTab C1059-HL Battery Replacement: adım 2, 2 resimden 1. Jazz UltraTab C1059-HL Battery Replacement: adım 2, 2 resimden 2.
      • Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
      FixBot'a Sor
      Yorum Ekle
    3. Jazz UltraTab C1059-HL Battery Replacement: adım 3, 1 resimden 1.
      • Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
      FixBot'a Sor
      Yorum Ekle
    4. Jazz UltraTab C1059-HL Battery Replacement: adım 4, 2 resimden 1. Jazz UltraTab C1059-HL Battery Replacement: adım 4, 2 resimden 2.
      • Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Jazz UltraTab C1059-HL Battery Replacement: adım 5, 1 resimden 1.
      • You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Austen Shields
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 üyesi
IUPUI-WILSON-F15S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 818
