Ana içeriğe geç
Jazz UltraTab C1059-HL Headphone Jack Replacement
Neye ihtiyacın var
  1. Jazz UltraTab C1059-HL Headphone Jack  Replacement, Headphone Jack: adım 1, 1 resimden 1.
    • Use a Philips screwdriver to remove the four screws: two at the top and two at the bottom of the device.
  2. Jazz UltraTab C1059-HL Headphone Jack  Replacement: adım 2, 2 resimden 1. Jazz UltraTab C1059-HL Headphone Jack  Replacement: adım 2, 2 resimden 2.
    • Place the device screen down on the table and use a pry tool to remove the back panel.
  3. Jazz UltraTab C1059-HL Headphone Jack  Replacement: adım 3, 1 resimden 1.
    • For your safety, remove the battery.
    • Using a solder iron, remove the wires connecting the battery to the motherboard.
  4. Jazz UltraTab C1059-HL Headphone Jack  Replacement: adım 4, 2 resimden 1. Jazz UltraTab C1059-HL Headphone Jack  Replacement: adım 4, 2 resimden 2.
    • Remove the screw attaching the motherboard to the back panel. Gently remove the motherboard.
  5. Jazz UltraTab C1059-HL Headphone Jack  Replacement: adım 5, 1 resimden 1.
    • The headphone jack is attached to the motherboard, so the whole thing must be replaced.
    • With the new mother board, use these steps in reverse to reassemble the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tim Poe
361 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 üyesi
IUPUI-WILSON-F15S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 114
