Giriş
This guide will guide the user to effectively remove and replace the speaker. This replacement will take around 15-20 minutes. However, if the guide is followed to the letter, the task will be accomplished with minimal damage to the device.
Neye ihtiyacın var
Start by removing the back panel.
Remove the 4 screws holding the device together: two on the left side, and two on the right side.
Using a metal spudger, carefully pry open the case.
Bir başkası bu kılavuzu tamamladı.
