Ana içeriğe geç
Jazz UltraTab C1059-HL Speaker Replacement
Neye ihtiyacın var
  1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: adım 1, 2 resimden 1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Start by removing the back panel.
    • Remove the 4 screws holding the device together: two on the left side, and two on the right side.
    • Using a metal spudger, carefully pry open the case.
    • With the screws gone, the case is held together with clips along the outside edge of the aluminum backplate.
    • Undoing these clips can take a bit of force. Be cautious not to damage the plastic edge of the device.
  2. Jazz UltraTab C1059-HL Speaker Replacement: adım 2, 1 resimden 1.
    • Place the device on the table with the screen-side down.
  3. Jazz UltraTab C1059-HL Speaker Replacement: adım 3, 1 resimden 1.
    • This is the Speaker.
    • Remove the two black screws.
  4. Jazz UltraTab C1059-HL Speaker Replacement: adım 4, 1 resimden 1.
    • Remove black tape from the wires.
    • Keep this tape, you will need it for reassembly.
  5. Jazz UltraTab C1059-HL Speaker Replacement: adım 5, 1 resimden 1.
    • Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
    • Remove Speaker wires when the solder liquifies.
    • Remember to make note of where each wire is connected. When reinstalling the speaker, it is important that the wires are reattached to the same spot.
  6. Jazz UltraTab C1059-HL Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the speaker.
    • Replace the speaker by following these steps in reverse.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tim Poe
361 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 üyesi
IUPUI-WILSON-F15S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 113
