Giriş
Soldering skills are required to replace the battery in this device. Check out iFixit's Soldering Skills guide for more help.
Neye ihtiyacın var
Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
Remove the yellow tape from the sides of the battery, and the surrounding components.
Bir Yorum
Very good instructions.....but where do I buy the repkacement battery from?
