Ana içeriğe geç
Jensen JTA-230 Motor Replacement
Neye ihtiyacın var
  1. Jensen JTA-230 Motor Replacement, Turntable Platter: adım 1, 1 resimden 1.
    • Remove Cover from record player.
  2. Jensen JTA-230 Motor Replacement: adım 2, 1 resimden 1.
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Motor Replacement: adım 3, 1 resimden 1.
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Motor Replacement: adım 4, 1 resimden 1.
    • Replace rubber plugs
  5. Jensen JTA-230 Motor Replacement: adım 5, 1 resimden 1.
    • Replace Cover
  6. Jensen JTA-230 Motor Replacement, Motor: adım 6, 2 resimden 1. Jensen JTA-230 Motor Replacement, Motor: adım 6, 2 resimden 2.
    • After removal of the turntable platter, 3 small screws can be seen. Remove the 3 screws which hold the motor in place.
    • On both the right and left side, there are 3 screws, remove each of them.
  7. Jensen JTA-230 Motor Replacement: adım 7, 2 resimden 1. Jensen JTA-230 Motor Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Gently Pull the top off of the sides and flip over to reveal the circuitry.
    • To remove the top entirely, remove each electrical connection with a pair of tweezers. There are 3, each connecting to the speakers.
  8. Jensen JTA-230 Motor Replacement: adım 8, 1 resimden 1.
    • Remove the Motor from the record player
    • Using a soldering iron, remove the motor from the circuitry.
    • Replace motor with new one.
Sonuç
Robert Wilcox
227 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G8
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,082
