Ana içeriğe geç
Jensen JTA-230 Speaker Replacement
Neye ihtiyacın var
    • First, open the dust cover and grab it by the hinges and pull up until it slides out.
    • Then, using a screwdriver unscrew the 3 screws on each side and remove the top layer of the record player. The top should pop out.
  1. Jensen JTA-230 Speaker Replacement: adım 2, 2 resimden 1. Jensen JTA-230 Speaker Replacement: adım 2, 2 resimden 2.
    • You should see the speakers(one on both side). From here, you want to unscrew the three screws holding them in place, using the same head as the previous step.
  2. Jensen JTA-230 Speaker Replacement: adım 3, 1 resimden 1.
    • Carefully remove the speakers from the device, being careful not to harm any components of the speaker.
  3. Jensen JTA-230 Speaker Replacement: adım 4, 1 resimden 1.
    • Once the speaker is out of the device, you should use a soldering iron to take off the wires on the current broken speaker, and put them to the new speaker using a soldering iron.
Sonuç
John Roche
175 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G8
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
What type of speakers do I need to buy?
Isaac Bott - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 600
