Ana içeriğe geç
Jensen JTA-230 Turntable Platter Replacement
Neye ihtiyacın var
  1. Jensen JTA-230 Turntable Platter Replacement, Turntable Platter: adım 1, 1 resimden 1.
    • Remove Cover from record player.
  2. Jensen JTA-230 Turntable Platter Replacement: adım 2, 1 resimden 1.
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Turntable Platter Replacement: adım 3, 1 resimden 1.
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Turntable Platter Replacement: adım 4, 1 resimden 1.
    • Replace rubber plugs
  5. Jensen JTA-230 Turntable Platter Replacement: adım 5, 1 resimden 1.
    • Replace Cover
Sonuç
Robert Wilcox
227 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G8
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
There's an important step missing here in that there is a "C" clip on the center pin that you need to remove. Also, this does not include how to replace the belt onto the motor, which is vital in restoring how a record player functions. Can you please update with this information?
ironman175 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 1,645
