Giriş
What to do if Xiaomi Mi Power Bank 2S suddenly does not charge phone nor charge itself and only action is faint battery level LED jerking? This may be answer.
Kid complained about his USB power bank. It refused to charge phone nor charged itself. On cable connecting and button pressing power bank responded with faint random battery level LED jerking. No rattling inside or noticeable physical damage. Started to think about too discharged battery when charging controller can refuse to charge. The only option left was disassembling to see what happened.
Parçalar
Hiçbir parça belirtilmedi.
Mi power bank disassembling require semi-soft and flat prying tool for back plate removal and Phillips #0 and Phillips #000 size screwdrivers. And some thin and flat metal strip to loose internal frame if needed. iFixit Essential Electronics Toolkit cover all these things.
Nut driver in picture usually is not required. I used it to put bent aluminium case corner back in shape when internals was pulled out.
Top and bottom covers are glued with double sided tape. Insert prying tool at middle of bottom cover with model name. Slide it around cover to loose glue.
Remove two screws at corners with Philips #0 screwdriver.
Turn power bank with sockets to bottom direction. Shake and pull internal frame out. If frame stuck, press several times at middle of case in all case length. Jimmy knife or thin metal stripe can be used carefully to free front side plate from outer case.
Charging controller circuit board is locked to frame with two little screws and two frame fixing pins at sides. Remove screws with Philips #000 screwdriver. Carefully bend fixing pins aside to loose board.
Battery is glued to frame with weak glue. Use prying tool or plastic card to loose battery from frame.
Remove teared battery terminal piece from controller board battery pad. Or flatten it if removal is not possible. Put solder blob over pad.
Put solder on end of battery terminal strip. Keep temperature between 250..270C degrees.
Solder battery terminal to controller board pad.
Assemble power bank back in reverse order. Install controller plate and battery back in frame.
Insert assembled internal frame in outer case. Screw it to with two #0 screws. Put back cover in place.
Xiaomi Mi Power Bank 2S appeared easy for basic repairs. Glued parts are easy to remove and they stick back just fine. Internals are fixed by screws. Other Mi USB power banks from 2 line (2c, 2i) are built in same way.
Described USB power bank have good charging capacity and is easy for everyday use. Keep in mind that design is not rugged and battery terminals inside are thin metal strips. Try to avoid dropping it on hard surfaces. Kid admitted that he droped his power bank several times - hard to hide dents at outer case corners :)
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Pretty straight forward tutorial, I wish i had the tools to repair it, I have it since 2018, never really used it, and now when I tried to charge it , the lights blink for a sec and then nothing. I wish I could get a replacement for free but the warranty has expired since 2019. I will probably take it for recycling unless I find someone to give it to.
