Ana içeriğe geç
Jewelry Clasp Replacement
Neye ihtiyacın var
  1. Jewelry Clasp Replacement, Clasp: adım 1, 2 resimden 1. Jewelry Clasp Replacement, Clasp: adım 1, 2 resimden 2.
    • Locate the jump ring, which is the link between the clasp and the chain.
    • On the jump ring, locate the slit.
  2. Jewelry Clasp Replacement: adım 2, 3 resimden 1. Jewelry Clasp Replacement: adım 2, 3 resimden 2. Jewelry Clasp Replacement: adım 2, 3 resimden 3.
    • Use one pair of flat nose pliers to gently grip the jump ring on one side of the slit.
    • Use the other pair of flat nose pliers to grip the jump ring on the opposite side of the slit.
  3. Jewelry Clasp Replacement: adım 3, 2 resimden 1. Jewelry Clasp Replacement: adım 3, 2 resimden 2.
    • To create a gap large enough to remove the clasp, twist one hand away from you while simultaneously twisting the other hand towards you.
    • Stop twisting once the gap is large enough for the clasp to be removed, and remove the old clasp.
    • Be careful not to twist outwards with the pliers or you will disfigure the jump ring.
  4. Jewelry Clasp Replacement: adım 4, 3 resimden 1. Jewelry Clasp Replacement: adım 4, 3 resimden 2. Jewelry Clasp Replacement: adım 4, 3 resimden 3.
    • If a new jump ring is needed, first remove the chain from the old jump ring.
    • Then, grab a new jump ring, locate its slit, and twist it open using the two pliers once again.
  5. Jewelry Clasp Replacement: adım 5, 3 resimden 1. Jewelry Clasp Replacement: adım 5, 3 resimden 2. Jewelry Clasp Replacement: adım 5, 3 resimden 3.
    • Slide the chain and the clasp onto the new jump ring.
    • To close the jump ring, use one pair of flat nose pliers to grab either side of the slit.
    • Begin twisting the ends of the jump ring toward each other until they meet once again.
  6. Jewelry Clasp Replacement: adım 6, 3 resimden 1. Jewelry Clasp Replacement: adım 6, 3 resimden 2. Jewelry Clasp Replacement: adım 6, 3 resimden 3.
    • If the gap remains, twist the jump ring so that the two ends are not aligned.
    • Keeping one pair of pliers gripped on the jump ring, use the other pair to gently squeeze the rim of the ring bringing the ends closer together.
    • Once this is done, return the nose pliers to their original position on either side of the slit and twist until the two ends meet.
    • Be careful not to squeeze the rim too tightly or the jump ring will be disfigured.
Sonuç
Enjoy your newly wearable piece of jewelry! If another clasp breaks, you know exactly how to replace it.
3 farklı kişi bu kılavuzu tamamladı.
Breanna Tran
239 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-6, Green Spring 2015 Cal Poly, Team 30-6, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G6
2 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 132
Her zaman: 7,226
