Ana içeriğe geç
John Frieda JFHA5R Reset and Test Buttons Replacement
Neye ihtiyacın var
  1. John Frieda JFHA5R Reset and Test Buttons Replacement, Reset and Test Buttons: adım 1, 1 resimden 1.
    • Make sure the Salon Shape brush is unplugged, and do not use metals once you have pried open the power plug.
    • Unscrew the two screws using a 3.0 mm bit triangle head on the back of the power plug.
  2. John Frieda JFHA5R Reset and Test Buttons Replacement: adım 2, 1 resimden 1.
    • Use the spudger along either side to open up the power plug.
    • As the power plug is opened, the caution sticker on top of the plug will rip.
  3. John Frieda JFHA5R Reset and Test Buttons Replacement: adım 3, 1 resimden 1.
    • Slide slightly up to remove the back cover of the power plug.
  4. John Frieda JFHA5R Reset and Test Buttons Replacement: adım 4, 1 resimden 1.
    • Remove the red reset button by pulling it to the right.
  5. John Frieda JFHA5R Reset and Test Buttons Replacement: adım 5, 1 resimden 1.
    • Pull slightly left then up to remove the yellow test button.
Sonuç
Lindsey Farley
113 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S5-G1, Baechle Fall 2017 IUPUI, Team S5-G1, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S5G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 475
