Ana içeriğe geç
Jumper Angelsounds JPD-100S The Transducer Replacement
Neye ihtiyacın var
  1. Jumper Angelsounds JPD-100S The Transducer  Replacement, Motherboard: adım 1, 1 resimden 1.
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 2, 2 resimden 1. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 2, 2 resimden 2.
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 3, 1 resimden 1.
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 4, 2 resimden 1. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 4, 2 resimden 2.
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 5, 2 resimden 1. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 5, 2 resimden 2.
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 6, 1 resimden 1.
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 7, 1 resimden 1.
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S The Transducer  Replacement, The Transducer: adım 8, 1 resimden 1.
    • Unsolder the Black cable
  9. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 9, 2 resimden 1. Jumper Angelsounds JPD-100S The Transducer  Replacement: adım 9, 2 resimden 2.
    • Unsolder the red cables from the metal plates.
Sonuç
Muosa Almubarak
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S6G1
6 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 320
