Ana içeriğe geç
Jumper EZbook S5 Touchpad Replacement
Neye ihtiyacın var
  1. Jumper EZbook S5 Touchpad Replacement, Touchpad: adım 1, 2 resimden 1. Jumper EZbook S5 Touchpad Replacement, Touchpad: adım 1, 2 resimden 2.
    • Place the laptop so the bottom is facing upwards.
    • Remove the two 8 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the three 5 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the six 4 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the single 3 mm base screw inside the battery case using a T3 Torx screwdriver.
  2. Jumper EZbook S5 Touchpad Replacement: adım 2, 3 resimden 1. Jumper EZbook S5 Touchpad Replacement: adım 2, 3 resimden 2. Jumper EZbook S5 Touchpad Replacement: adım 2, 3 resimden 3.
    • Detach the battery case using the flat end of a spudger.
  3. Jumper EZbook S5 Touchpad Replacement: adım 3, 3 resimden 1. Jumper EZbook S5 Touchpad Replacement: adım 3, 3 resimden 2. Jumper EZbook S5 Touchpad Replacement: adım 3, 3 resimden 3.
    • Pry apart the bottom cover of the laptop using the flat end of a spudger.
  4. Jumper EZbook S5 Touchpad Replacement: adım 4, 3 resimden 1. Jumper EZbook S5 Touchpad Replacement: adım 4, 3 resimden 2. Jumper EZbook S5 Touchpad Replacement: adım 4, 3 resimden 3.
    • Remove the four 4 mm screws from the battery using a T3 Torx screwdriver.
  5. Jumper EZbook S5 Touchpad Replacement: adım 5, 3 resimden 1. Jumper EZbook S5 Touchpad Replacement: adım 5, 3 resimden 2. Jumper EZbook S5 Touchpad Replacement: adım 5, 3 resimden 3.
    • Flip the battery to the opposite side of the touchpad.
  6. Jumper EZbook S5 Touchpad Replacement: adım 6, 3 resimden 1. Jumper EZbook S5 Touchpad Replacement: adım 6, 3 resimden 2. Jumper EZbook S5 Touchpad Replacement: adım 6, 3 resimden 3.
    • Detach the tape on the left side of the touchpad shown in the first two images.
    • Use a heat gun or a hair dryer to melt the glue quickly.
  7. Jumper EZbook S5 Touchpad Replacement: adım 7, 3 resimden 1. Jumper EZbook S5 Touchpad Replacement: adım 7, 3 resimden 2. Jumper EZbook S5 Touchpad Replacement: adım 7, 3 resimden 3.
    • Detach the tape on the right side of the touchpad shown in all three images.
    • Use a hair dryer or a heat gun to soften the glue.
  8. Jumper EZbook S5 Touchpad Replacement: adım 8, 3 resimden 1. Jumper EZbook S5 Touchpad Replacement: adım 8, 3 resimden 2. Jumper EZbook S5 Touchpad Replacement: adım 8, 3 resimden 3.
    • Use a spudger to detach the touchpad from the top case.
    • The touchpad is attached to the top case with glue. Use a hair dryer or a heat gun to soften the glue.
    • Be patient. Step 8 can take up to 8 hours if you work by yourself.
    • Don't aim the heat gun or the hair dryer anywhere other than the top case.
  9. Jumper EZbook S5 Touchpad Replacement: adım 9, 3 resimden 1. Jumper EZbook S5 Touchpad Replacement: adım 9, 3 resimden 2. Jumper EZbook S5 Touchpad Replacement: adım 9, 3 resimden 3.
    • Lift the touchpad out of the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zed Chen
223 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 1,393
