Giriş
The ceramic valve controls which way the fresh water will flow - to the coffee preparation, to the hot water spout or to the steam nozzle. The ceramic valve May leak or become defective. Replacing it is quite simple.
Neye ihtiyacın var
Remove the water tank and the drip tray. Remove all coffee beans from the storage container.
Find the ceramic valve at the bottom behind the right side panel It is slid onto a black plastic support plate and connected with two cable connections and three hoses.
Using your finger press the black plastic detent down.
Push the ceramic valve upward to the right.
If you want to replace the valve, you have to disconnect all cables and hoses. If you are only removing the valve to access other components (outlet valve, heat exchanger), you do not need to disconnect the connections.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
2 Yorum
Great and clear guide which helped me take apart my device with ease. Question, what type of failure mode does the device exhibit when this needs replacing? My Jura IMPRESSA won't output any water when cleaning is selected. Unsure if this might be the cause.
As far als I know its Error 6
VauWeh -
