Ana içeriğe geç
Jura Impressa C E F Models Flowmeter replacement
Neye ihtiyacın var
  1. Jura Impressa C E F Models Flowmeter replacement, Jura Impressa Type C E F opening procedure: adım 1, 1 resimden 1.
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Jura Impressa C E F Models Flowmeter replacement: adım 2, 3 resimden 1. Jura Impressa C E F Models Flowmeter replacement: adım 2, 3 resimden 2. Jura Impressa C E F Models Flowmeter replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • You can even create your own specialty tool
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Jura Impressa C E F Models Flowmeter replacement, Flowmeter replacement: adım 3, 1 resimden 1.
    • The flowmeter is the white round box in the back of the unit. It has to be removed for revision, but that won’t be difficult.
    • Slide the two silicone tubes off the flowmeter.
  4. Jura Impressa C E F Models Flowmeter replacement: adım 4, 3 resimden 1. Jura Impressa C E F Models Flowmeter replacement: adım 4, 3 resimden 2. Jura Impressa C E F Models Flowmeter replacement: adım 4, 3 resimden 3.
    • Tilt the unit to the side so that you can reach the base plate. The flowmeter has a pin on the bottom that is attached to the base plate with a clamping ring.
    • A second pin fixes the position of the flowmeter.
    • Gently prise off the clamping ring with a flathead screwdriver or spudger. When levering, start at different points.
  5. Jura Impressa C E F Models Flowmeter replacement: adım 5, 2 resimden 1. Jura Impressa C E F Models Flowmeter replacement: adım 5, 2 resimden 2.
    • Lift out the flowmeter. The cables can also remain plugged in.
  6. Jura Impressa C E F Models Flowmeter replacement: adım 6, 3 resimden 1. Jura Impressa C E F Models Flowmeter replacement: adım 6, 3 resimden 2. Jura Impressa C E F Models Flowmeter replacement: adım 6, 3 resimden 3.
    • Blow into the flowmeter at the lower nozzle. Air should flow easily and you should hear the turbine whirring.
    • The upper half of the flowmeter is locked in place with a bayonet catch. Turn the upper part slightly counterclockwise.
    • Lift off the upper half. Watch out for the sealing ring. The turbine can be lifted out easily.
    • Now you can clean and decalcify everything well. In particular, clean the inlet spout, e.g. with a needle or other suitable thin object as the opening is quite narrow.
    • If the turbine does not run easily now, the flowmeter must be replaced. The sensor itself may also be defective.
Sonuç
Follow the steps in reverse order to reassemble your device.
Bu çevirmenlere özel teşekkürler:
de en
100%
carlotremolada dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
VauWeh
252.704 İtibar
286 adet Kılavuz yazıldı
Ekip
Repair is War on Entropy Repair is War on Entropy üyesi
Community
29 Üyeler
1.764 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 112
Her zaman: 1,289
