Ana içeriğe geç
Jura Impressa C E F models grindstone replacement
  1. Jura Impressa C E F models grindstone replacement, Jura Impressa C E F models grindstone replacement: adım 1, 1 resimden 1.
    • The instructions apply to almost all devices from Jura and similar devices from AEG, Krups. The success of the repair is striking!
    • The picture shows the old grind stones on the left and the new ones on the right. They consist of a grinding ring and a grinding cone.
    • For this repair, the side parts do not necessarily have to be removed.
  2. Jura Impressa C E F models grindstone replacement: adım 2, 2 resimden 1. Jura Impressa C E F models grindstone replacement: adım 2, 2 resimden 2.
    • Pull the grinder adjuster up. Note the setting, it is best to take a photo of it.
    • The screws that hold the coffee container are located in two recesses. First clean, then loosen. The protective cover over the grinder does not need to be removed.
Sonuç
Follow the steps in reverse order to reassemble your device
Bu çevirmenlere özel teşekkürler:
de en
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
VauWeh
252.704 İtibar
286 adet Kılavuz yazıldı
Ekip
Repair is War on Entropy Repair is War on Entropy üyesi
Community
29 Üyeler
1.764 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 41
Her zaman: 431
