Giriş
A printed circuit board (PCB) mechanically supports and electronically connects electronic components using conductive tracks made of copper laminated onto a non-conductive plastic. The PCB reduces the amount of wires in a device and inherently makes any device more reliable. The step by step instructions will describe how to troubleshoot your PCB.
  1. Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device. Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Remove the 3 AAA batteries from the device.
    • Remove the 3 AAA batteries from the device.
  3. Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device. Pull apart the device once screws are loose, splitting the device in half.
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Keeping all wires connected to their attachments, place the front half of the device face down.
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  6. Inspect the printed circuit board for any breaks or cracks.
    • Inspect the printed circuit board for any breaks or cracks.
  7. Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board. Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  8. Disconnect all wires from the PCB Remove the damaged PCB from the microphone
    • Disconnect all wires from the PCB
    • Remove the damaged PCB from the microphone
    • Place new PCB in the Justin Bieber Concert Microphone.
    • Connect all the wires to the new PCB using this soldering guide.
Sonuç
Mike Seyman
425 İtibar
4 adet Kılavuz yazıldı
Takım
Baylor, Team 4-1, Williams Fall 2014 Baylor, Team 4-1, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G1
3 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 162
