Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the phone over to expose the battery cover.
Apply pressure to the back of the battery cover to slide it down.
The battery cover is now separate from the phone.
Remove the battery by pushing it up and out from the bottom.
The battery, cover, and phone should now be separated.
Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
Beneath the covers are screws.
Use the iPod pry tool to remove the outer screen.
Two screws are now visible.
Use the iPod pry tool to loosen the faceplate from the phone.
Turn the phone over.
Place a spudger in the oval shaped speaker opening of the phone (indicated by the red rectangle).
Turn the phone so the exposed circuit board faces upward.
Push the spudger through the speaker opening to separate the speaker (indicated by the yellow rectangle).
Bu adımda kullanılan alet:Tweezers$4.99-
Grasp the speaker (indicated by the yellow rectangle) with tweezers, or with your fingers if you can manage a firm grip.
Firmly remove the speaker.
Bir başkası bu kılavuzu tamamladı.
