Ana içeriğe geç
KPN Arizona Comfort Replacement
Neye ihtiyacın var
  1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: adım 1, 3 resimden 1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: adım 1, 3 resimden 2. KPN Arizona Comfort Replacement, KPN Arizona Comfort: adım 1, 3 resimden 3.
    • Hold the phone with one hand and apply a slight pressure on the battery lid with your other hand.
    • Now you can slide open the battery lid.
  2. KPN Arizona Comfort Replacement: adım 2, 1 resimden 1.
    • Lift out both batteries with a prying movement.
  3. KPN Arizona Comfort Replacement: adım 3, 3 resimden 1. KPN Arizona Comfort Replacement: adım 3, 3 resimden 2. KPN Arizona Comfort Replacement: adım 3, 3 resimden 3.
    • Remove the following two Phillips #00 screws securing the back casing to the front.
  4. KPN Arizona Comfort Replacement: adım 4, 3 resimden 1. KPN Arizona Comfort Replacement: adım 4, 3 resimden 2. KPN Arizona Comfort Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to pry the front from the backside.
    • Start prying at the bottom and work your way around the device.
    • Do this for every 3 cm all around.
    • If you apply too much pressure or use a sharp tool, this might damage the casing.
  5. KPN Arizona Comfort Replacement: adım 5, 3 resimden 1. KPN Arizona Comfort Replacement: adım 5, 3 resimden 2. KPN Arizona Comfort Replacement: adım 5, 3 resimden 3.
    • Flip the circuit board from the backside of the phone to the frontside of the phone by tilting it on the long edge
    • Make sure you do this gesture slowly and gently so the wires will not detach.
  6. KPN Arizona Comfort Replacement: adım 6, 3 resimden 1. KPN Arizona Comfort Replacement: adım 6, 3 resimden 2. KPN Arizona Comfort Replacement: adım 6, 3 resimden 3.
    • You are now facing the back side. Apply a little bit of pressure with the plastic opening tool on the back of the speaker so the the speaker can pop out.
    • The speaker is still attached with a wire, do not pull this.
  7. KPN Arizona Comfort Replacement: adım 7, 2 resimden 1. KPN Arizona Comfort Replacement: adım 7, 2 resimden 2.
    • Use a soldering iron to heat up the solder connected to the electric wire.
    • When the solder is fluid, carefully pull the electric wire loose.
  8. KPN Arizona Comfort Replacement: adım 8, 2 resimden 1. KPN Arizona Comfort Replacement: adım 8, 2 resimden 2.
    • Replace the broken speaker of the phone and solder it back in place.
Sonuç
To reassemble your device, follow these instructions from step 6 in reverse order.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 43
Her zaman: 929
