Ana içeriğe geç
KYVOL CYBOVAC E20 Motherboard Replacement
Neye ihtiyacın var
  1. KYVOL CYBOVAC E20 Motherboard Replacement, Battery: adım 1, 2 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Start by laying the device on a flat surface with the logo facing up.
    • Flip the device over.
  2. KYVOL CYBOVAC E20 Motherboard Replacement: adım 2, 2 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove two 1 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Motherboard Replacement: adım 3, 2 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the cover.
  4. KYVOL CYBOVAC E20 Motherboard Replacement: adım 4, 2 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 4, 2 resimden 2.
    • Lift the battery.
    • Press down on the top of the white connector.
    • Remove the battery from the vacuum.
  5. KYVOL CYBOVAC E20 Motherboard Replacement, Wheel: adım 5, 1 resimden 1.
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  6. KYVOL CYBOVAC E20 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  7. KYVOL CYBOVAC E20 Motherboard Replacement: adım 7, 3 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 7, 3 resimden 2. KYVOL CYBOVAC E20 Motherboard Replacement: adım 7, 3 resimden 3.
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
  8. KYVOL CYBOVAC E20 Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Remove the eight 15 mm screws on the device's underside using a Phillips #2 screwdriver
  9. KYVOL CYBOVAC E20 Motherboard Replacement: adım 9, 2 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the eight 10 mm screws with a Phillips #2 screwdriver to remove the bumper.
    • Disconnect the sensor wire from the front of the device.
  10. KYVOL CYBOVAC E20 Motherboard Replacement: adım 10, 2 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the dust bin from the device.
  11. KYVOL CYBOVAC E20 Motherboard Replacement: adım 11, 3 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 11, 3 resimden 2. KYVOL CYBOVAC E20 Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the main brush from the bottom of the device.
    • Remove the orange cover, then pop the brush out of its compartment.
  12. KYVOL CYBOVAC E20 Motherboard Replacement: adım 12, 2 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 12, 2 resimden 2.
    • Disconnect the ribbon cable between the top and bottom halves of the device and remove the top half away from the rest of the body.
  13. KYVOL CYBOVAC E20 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the three 10 mm screws from the motherboard using a Phillips #2 screwdriver.
  14. KYVOL CYBOVAC E20 Motherboard Replacement: adım 14, 3 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 14, 3 resimden 2. KYVOL CYBOVAC E20 Motherboard Replacement: adım 14, 3 resimden 3.
    • Detach the connections on the motherboard carefully.
  15. KYVOL CYBOVAC E20 Motherboard Replacement: adım 15, 3 resimden 1. KYVOL CYBOVAC E20 Motherboard Replacement: adım 15, 3 resimden 2. KYVOL CYBOVAC E20 Motherboard Replacement: adım 15, 3 resimden 3.
    • Continue removing the connections up until you are done removing all 19 of the motherboard connections.
    • Once all plugs are disconnected, lift the motherboard out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Blayde Johnson
181 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Summer 2023 IUPUI, Team 1-1, Harley Summer 2023 üyesi
IUPUI-HARLEY-SU23S1G1
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 136
