Ana içeriğe geç
KYVOL CYBOVAC E20 Wheel Assembly Replacement
Neye ihtiyacın var
  1. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: adım 1, 2 resimden 1. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Start by laying the device on a flat surface with the logo facing up.
    • Flip the device over.
  2. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 2, 2 resimden 1. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 2, 2 resimden 2.
    • Remove two 1 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 3, 2 resimden 1. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the cover.
  4. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 4, 2 resimden 1. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 4, 2 resimden 2.
    • Lift the battery.
    • Press down on the top of the white connector.
    • Remove the battery from the vacuum.
  5. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel: adım 5, 1 resimden 1.
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  6. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 6, 1 resimden 1.
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  7. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 7, 3 resimden 1. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 7, 3 resimden 2. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 7, 3 resimden 3.
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
  8. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: adım 8, 3 resimden 1. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: adım 8, 3 resimden 2. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: adım 8, 3 resimden 3.
    • Remove six 10 mm screws from the housing using a Phillips #00 screwdriver.
    • Open the gearbox.
  9. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 9, 1 resimden 1.
    • Gently remove each gear.
  10. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 10, 2 resimden 1. KYVOL CYBOVAC E20 Wheel Assembly Replacement: adım 10, 2 resimden 2.
    • Use a J1 screw driver to remove two 6 mm screws from the gearbox.
Sonuç
Randall Morgan
380 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Summer 2023 IUPUI, Team 1-1, Harley Summer 2023 üyesi
IUPUI-HARLEY-SU23S1G1
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 32
Her zaman: 276
