Ana içeriğe geç
KYVOL CYBOVAC E20 Wheel Replacement
Neye ihtiyacın var
  1. KYVOL CYBOVAC E20 Wheel Replacement, Wheel: adım 1, 1 resimden 1.
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  2. KYVOL CYBOVAC E20 Wheel Replacement: adım 2, 1 resimden 1.
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Wheel Replacement: adım 3, 3 resimden 1. KYVOL CYBOVAC E20 Wheel Replacement: adım 3, 3 resimden 2. KYVOL CYBOVAC E20 Wheel Replacement: adım 3, 3 resimden 3.
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
Sonuç
Randall Morgan
359 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Summer 2023 IUPUI, Team 1-1, Harley Summer 2023 üyesi
IUPUI-HARLEY-SU23S1G1
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 22
Her zaman: 276
