Giriş
Replacement of the thermocouple on any Kaffelogic Nano or Nucleus Link coffee roaster with a D or P prefix in the serial number.
Neye ihtiyacın var
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Remove the last 2.5mm Hex screw securing the rear panel.
Pull up on the rear panel to remove it from the roaster.
Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
Use a 2.0mm slotted screwdriver to remove the thermocouple wires from the PCB-A
Unwind the thermocouple wire from the earth lead.
Pinch the thermocouple and gently remove it from the tube.
Leave 2mm of thermocouple insulation exposed
Massage the tape firmly over the thermocouple wires to secure the position.
