Ana içeriğe geç
Karcher Pressure Washers 15209900 2018 Electrical Box Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Safety precautions: adım 1, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Safety precautions: adım 1, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Safety precautions: adım 1, 3 resimden 3.
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • Unscrew the output hose from the pressure washer.
  2. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the rubber strap: adım 2, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the rubber strap: adım 2, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the rubber strap: adım 2, 3 resimden 3.
    • Unlatch and remove the yellow rubber strap.
  3. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the hand grip: adım 3, 1 resimden 1.
    • Use a T20 driver to remove the two 55mm-long screws securing the hand grip.
  4. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the hand grip: adım 4, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the hand grip: adım 4, 2 resimden 2.
    • Remove the hand grip from the extension bars.
  5. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the top panels: adım 5, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the top panels: adım 5, 2 resimden 2.
    • Use a T15 driver to remove the six screws securing the top black plastic panels on either side of the device.
  6. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the top panels: adım 6, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the top panels: adım 6, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the top panels: adım 6, 3 resimden 3.
    • Remove the two plastic panels.
  7. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the plastic feet: adım 7, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the plastic feet: adım 7, 2 resimden 2.
    • Remove the two T15 screws securing the plastic feet—one screw on either side.
  8. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the plastic feet: adım 8, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the plastic feet: adım 8, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the plastic feet: adım 8, 3 resimden 3.
    • Unclip and remove the plastic feet.
  9. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the housing: adım 9, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the housing: adım 9, 2 resimden 2.
    • Use a T15 driver to remove the ten screws securing the housing halves together.
    • Remove the T15 screw underneath the wheel axle.
  10. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the housing: adım 10, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the housing: adım 10, 2 resimden 2.
    • Set the device on its side.
    • Lift the housing half away from the body.
    • If the housing half does not separate, check to make sure you removed all the body screws.
    • Remove the housing.
    • Screws may get stuck inside the plastic housing. Be careful not to lose any screws.
  11. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Release the cord strain relief: adım 11, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Release the cord strain relief: adım 11, 2 resimden 2.
    • Slide the power cord strain relief out its notch on the plastic housing.
  12. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the motor: adım 12, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the motor: adım 12, 2 resimden 2.
    • Lift the motor assembly out of the plastic housing and set it aside.
  13. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Reassembly tip: adım 13, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Reassembly tip: adım 13, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Reassembly tip: adım 13, 3 resimden 3.
    • Reassembly tip: Use these images to help reassemble the housing back around the motor.
    • Make sure that all five bushings are in place.
    • In order for the housing to fit properly, the bushings must fit in their respective mounts.
    • Make sure that the yellow tube is properly notched onto the housing.
    • Make sure that the power cord strain relief sits correctly in the housing notch.
  14. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the electrical box cover: adım 14, 1 resimden 1.
    • Use a T20 driver to remove the four screws securing the electrical box cover.
  15. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the electrical box cover: adım 15, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the electrical box cover: adım 15, 2 resimden 2.
    • Lift the cover off of the electrical box.
  16. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Loosen the capacitor: adım 16, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Loosen the capacitor: adım 16, 2 resimden 2.
    • Tilt the capacitor upward slightly to gain access to the connectors.
  17. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unplug the capacitor: adım 17, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unplug the capacitor: adım 17, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unplug the capacitor: adım 17, 3 resimden 3.
    • Use your fingers to pull each capacitor connector directly off of their spade plug.
  18. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the capacitor: adım 18, 1 resimden 1.
    • Remove the capacitor.
    • Reassembly note: The wires are non-polarized and can connect into either plug on the capacitor.
  19. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the plate spring: adım 19, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the plate spring: adım 19, 2 resimden 2.
    • Remove the plate spring from the electrical box.
  20. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement: adım 20, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement: adım 20, 2 resimden 2.
    • Pull the switch out of the electrical box.
    • Disconnect the four spade connectors from the the switch.
  21. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the switch: adım 21, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the switch: adım 21, 2 resimden 2.
    • Remove the switch.
    • Reassembly tip: Use the second photo as a reference to help you properly re-wire the switch.
  22. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the grounding screw: adım 22, 1 resimden 1.
    • Use a flat head screwdriver to remove the screw securing the ground wire in the electrical box.
  23. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Unscrew the electrical box: adım 23, 1 resimden 1.
    • Use a T30 driver to remove the two bolts securing the electrical box to the motor assembly.
  24. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the electrical box: adım 24, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the electrical box: adım 24, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Electrical Box Replacement, Remove the electrical box: adım 24, 3 resimden 3.
    • Lift the electrical box away from the motor assembly, taking care to feed the wires through the cutout.
    • Remove the electrical box.
Sonuç
Arthur Shi
283.268 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.631 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 24
