Ana içeriğe geç
Karcher Pressure Washers 15209900 2018 Motor Replacement
Neye ihtiyacın var
  1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: adım 1, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: adım 1, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: adım 1, 3 resimden 3.
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • Unscrew the output hose from the pressure washer.
  2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: adım 2, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: adım 2, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: adım 2, 3 resimden 3.
    • Unlatch and remove the yellow rubber strap.
  3. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the hand grip: adım 3, 1 resimden 1.
    • Use a T20 driver to remove the two 55mm-long screws securing the hand grip.
  4. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the hand grip: adım 4, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the hand grip: adım 4, 2 resimden 2.
    • Remove the hand grip from the extension bars.
  5. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the top panels: adım 5, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the top panels: adım 5, 2 resimden 2.
    • Use a T15 driver to remove the six screws securing the top black plastic panels on either side of the device.
  6. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: adım 6, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: adım 6, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: adım 6, 3 resimden 3.
    • Remove the two plastic panels.
  7. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the plastic feet: adım 7, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the plastic feet: adım 7, 2 resimden 2.
    • Remove the two T15 screws securing the plastic feet—one screw on either side.
  8. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: adım 8, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: adım 8, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: adım 8, 3 resimden 3.
    • Unclip and remove the plastic feet.
  9. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the housing: adım 9, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the housing: adım 9, 2 resimden 2.
    • Use a T15 driver to remove the ten screws securing the housing halves together.
    • Remove the T15 screw underneath the wheel axle.
  10. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the housing: adım 10, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the housing: adım 10, 2 resimden 2.
    • Set the device on its side.
    • Lift the housing half away from the body.
    • If the housing half does not separate, check to make sure you removed all the body screws.
    • Remove the housing.
    • Screws may get stuck inside the plastic housing. Be careful not to lose any screws.
  11. Karcher Pressure Washers 15209900 2018 Motor Replacement, Release the cord strain relief: adım 11, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Release the cord strain relief: adım 11, 2 resimden 2.
    • Slide the power cord strain relief out its notch on the plastic housing.
  12. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor: adım 12, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor: adım 12, 2 resimden 2.
    • Lift the motor assembly out of the plastic housing and set it aside.
  13. Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: adım 13, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: adım 13, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: adım 13, 3 resimden 3.
    • Reassembly tip: Use these images to help reassemble the housing back around the motor.
    • Make sure that all five bushings are in place.
    • In order for the housing to fit properly, the bushings must fit in their respective mounts.
    • Make sure that the yellow tube is properly notched onto the housing.
    • Make sure that the power cord strain relief sits correctly in the housing notch.
  14. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the electrical box cover: adım 14, 1 resimden 1.
    • Use a T20 driver to remove the four screws securing the electrical box cover.
  15. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box cover: adım 15, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box cover: adım 15, 2 resimden 2.
    • Lift the cover off of the electrical box.
  16. Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the capacitor: adım 16, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the capacitor: adım 16, 2 resimden 2.
    • Tilt the capacitor upward slightly to gain access to the connectors.
  17. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: adım 17, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: adım 17, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: adım 17, 3 resimden 3.
    • Use your fingers to pull each capacitor connector directly off of their spade plug.
  18. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the capacitor: adım 18, 1 resimden 1.
    • Remove the capacitor.
    • Reassembly note: The wires are non-polarized and can connect into either plug on the capacitor.
  19. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plate spring: adım 19, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plate spring: adım 19, 2 resimden 2.
    • Remove the plate spring from the electrical box.
  20. Karcher Pressure Washers 15209900 2018 Motor Replacement: adım 20, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement: adım 20, 2 resimden 2.
    • Pull the switch out of the electrical box.
    • Disconnect the four spade connectors from the the switch.
  21. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the switch: adım 21, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the switch: adım 21, 2 resimden 2.
    • Remove the switch.
    • Reassembly tip: Use the second photo as a reference to help you properly re-wire the switch.
  22. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the grounding screw: adım 22, 1 resimden 1.
    • Use a flat head screwdriver to remove the screw securing the ground wire in the electrical box.
  23. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the electrical box: adım 23, 1 resimden 1.
    • Use a T30 driver to remove the two bolts securing the electrical box to the motor assembly.
  24. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: adım 24, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: adım 24, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: adım 24, 3 resimden 3.
    • Lift the electrical box away from the motor assembly, taking care to feed the wires through the cutout.
    • Remove the electrical box.
  25. Karcher Pressure Washers 15209900 2018 Motor Replacement, Set the motor upright: adım 25, 1 resimden 1.
    • Set the motor assembly upright with the pump assembly on the top.
    • The pump assembly is filled with oil. This step prevents the oil from spilling out when you remove the pump.
  26. Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the pump assembly: adım 26, 1 resimden 1.
    • Use a 13mm socket to remove the four long bolts holding the pump assembly to the motor.
    • Re-assembly tip: The bolts hold the pump under pressure against the motor assembly. During reassembly, gradually tighten the bolts in a cross pattern.
  27. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump assembly: adım 27, 2 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump assembly: adım 27, 2 resimden 2.
    • Lift the pump assembly off of the motor.
  28. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump oil: adım 28, 1 resimden 1.
    • Pour the pump oil out of the motor housing. If the oil looks serviceable, save it for reassembly.
    • Reassembly tip: The piston assembly is sealed with oil, and the motor housing acts as an oil pan. Before you attach the pump to the motor, fill the piston well with oil, up to the bearing plate.
  29. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the bearing plate: adım 29, 1 resimden 1.
    • Remove the bearing plate from the motor assembly.
    • Reassembly tip: The side of the plate with the ringed groove should face the bearings.
  30. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the bearing ring: adım 30, 1 resimden 1.
    • Remove the bearing ring.
  31. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: adım 31, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: adım 31, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: adım 31, 3 resimden 3.
    • Pull the two rubber bushings off of each side of the motor.
  32. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: adım 32, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: adım 32, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: adım 32, 3 resimden 3.
    • Pull the black motor cover off of the motor assembly.
  33. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: adım 33, 3 resimden 1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: adım 33, 3 resimden 2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: adım 33, 3 resimden 3.
    • Insert a pry bar or a flat head screwdriver between the blower wheel and the motor assembly.
    • Pry to loosen the blower wheel from the motor.
    • Slide the blower wheel off of the motor assembly.
  34. Karcher Pressure Washers 15209900 2018 Motor Replacement: adım 34, 1 resimden 1.
    • Only the motor assembly remains.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
334.666 İtibar
848 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
25.563 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 55
Her zaman: 3,704
