Ana içeriğe geç
Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement
Neye ihtiyacın var
  1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the tank: adım 1, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the tank: adım 1, 2 resimden 2.
    • Before you begin, make sure to power off and unplug the device.
    • Lift the tank by the handle and remove it from the device.
  2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the transport wheels: adım 2, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the transport wheels: adım 2, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the transport wheels: adım 2, 3 resimden 3.
    • Press the yellow button near each wheel base to release the wheels.
    • Remove both wheels from their sockets.
  3. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Lower the suction bars: adım 3, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Lower the suction bars: adım 3, 2 resimden 2.
    • Press the yellow foot switch at the base of the device to lower the suction bars.
  4. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Lock the handle in place: adım 4, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Lock the handle in place: adım 4, 2 resimden 2.
    • Raise the handle to the upright position.
    • This will engage the carriage rollers and lift the device.
  5. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 5, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 5, 2 resimden 2.
    • Engage the retaining bracket to lock the handle in place.
  6. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Tilt the device over: adım 6, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Tilt the device over: adım 6, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Tilt the device over: adım 6, 3 resimden 3.
    • Grasp the handle and carefully tilt the device onto its side.
  7. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the roller brushes: adım 7, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the roller brushes: adım 7, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the roller brushes: adım 7, 3 resimden 3.
    • Tilt the top of the roller brush out of the brush well.
    • Remove both roller brushes.
  8. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the suction bars: adım 8, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the suction bars: adım 8, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the suction bars: adım 8, 3 resimden 3.
    • Press the yellow button on the suction bar retaining bracket to release the suction bar.
    • If you can't see the yellow button, press the yellow foot switch at the base of the device to lower the suction bars.
  9. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 9, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 9, 2 resimden 2.
    • Remove both suction bars.
    • Reassembly tip: When you re-insert the suction bars, be sure to orient the locking tab towards the center of the device. This allows the bars to click in place.
  10. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the pump cover: adım 10, 1 resimden 1.
    • Use a T20 driver to remove the three screws securing the pump cover.
  11. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 11, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 11, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 11, 3 resimden 3.
    • Remove the pump cover.
  12. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Disconnect the handle: adım 12, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Disconnect the handle: adım 12, 2 resimden 2.
    • Squeeze the right plug by the edges and pull it out of its socket.
    • During reassembly, make sure that all plugs are firmly seated in their sockets.
  13. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Loosen the left retaining bracket: adım 13, 1 resimden 1.
    • Remove the following screws securing the left retaining bracket:
    • Four T40 screws
    • Two T20 screws
  14. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Lock the handle in place: adım 14, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Lock the handle in place: adım 14, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Lock the handle in place: adım 14, 3 resimden 3.
  15. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the right splash guard: adım 15, 1 resimden 1.
    • Use a T20 driver to remove the two screws securing the right splash guard.
  16. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 16, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 16, 2 resimden 2.
    • Remove the right splash guard.
  17. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the right retaining bracket: adım 17, 1 resimden 1.
    • Use a T20 driver to remove the following screws securing the right retaining bracket:
    • Two 85 mm-long screws
    • Four 45 mm-long screws
  18. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 18, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 18, 2 resimden 2.
    • Remove the right retaining bracket.
  19. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the handle: adım 19, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the handle: adım 19, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the handle: adım 19, 3 resimden 3.
    • Lift the handle assembly away from the device and remove it.
  20. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Reassembly tip: adım 20, 1 resimden 1.
    • Reassembly tip: Be careful not to lose the two gray bushings on the ends of the handle assembly.
  21. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Disconnect the electrical plugs: adım 21, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Disconnect the electrical plugs: adım 21, 2 resimden 2.
    • Disconnect the two remaining plugs by squeezing the edges and pulling them out of their sockets.
    • The socket board should have no plugs connected to it.
    • Reassembly tip: The sockets reconnect to the following parts:
    • Vacuum motor
    • Pump
    • Handle
    • During reassembly, make sure to firmly seat all plugs in their sockets.
  22. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the brush housing: adım 22, 1 resimden 1.
    • Use a T20 driver to remove the six screws securing the plastic brush housing.
  23. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 23, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 23, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 23, 3 resimden 3.
    • Lift the brush housing away from the device and remove it.
  24. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Loosen the socket board: adım 24, 1 resimden 1.
    • Use a T20 driver to remove the two screws securing the socket board.
  25. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Disconnect the drive motor: adım 25, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Disconnect the drive motor: adım 25, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Disconnect the drive motor: adım 25, 3 resimden 3.
    • Squeeze the edges of the drive motor plug and disconnect it from the extension plug.
    • The drive motor plug has red, brown, and gray wires feeding into it.
  26. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 26, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 26, 2 resimden 2.
    • Free the motor wires from underneath the socket board.
    • Reassembly tip: Remember to feed the motor wires back underneath the socket board.
  27. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the gear case cover: adım 27, 1 resimden 1.
    • Use a T20 driver to remove the six bolts securing the gear case cover.
  28. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 28, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 28, 2 resimden 2.
    • Remove the gear case cover.
  29. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the ground screw: adım 29, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the ground screw: adım 29, 2 resimden 2.
    • Remove the following bolts from the gear case:
    • Six T20 bolts
    • One T30 bolt securing the ground wire
    • Reassembly tip: The ground wire's ring terminal should sandwich between a washer and a serrated washer.
  30. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the drive assembly: adım 30, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the drive assembly: adım 30, 2 resimden 2.
    • Lift the motor end of the drive assembly up slightly to clear the mounting lip.
    • Push the drive assembly out of its recess.
    • Reassembly tip: In order for the drive assembly to sit properly in its recess, the motor must clear the mounting lip. If you can't push the motor in far enough, lift it up slightly to clear the lip.
  31. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 31, 1 resimden 1.
    • Remove the drive assembly and stand it on the motor end.
  32. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Detach the gear case: adım 32, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Detach the gear case: adım 32, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Detach the gear case: adım 32, 3 resimden 3.
    • Use snap ring pliers to remove the retaining ring securing the motor axle.
  33. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 33, 1 resimden 1.
    • Use a T30 driver to remove the three bolts securing the gear case to the motor mount.
  34. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 34, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 34, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 34, 3 resimden 3.
    • Use a pry bar or flathead screwdriver to loosen the gear case from the motor mount.
  35. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 35, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 35, 2 resimden 2.
    • Lift the gear case away from the motor mount to remove it.
  36. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Reassembly tip: adım 36, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Reassembly tip: adım 36, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Reassembly tip: adım 36, 3 resimden 3.
    • During reassembly, follow these tips:
    • The motor axle is keyed into the gearbox. Rotate the axle until it aligns with the gearbox slot.
    • Align the gear case to the motor mount using the two alignment pins.
    • Once everything is aligned, gently tap the gear case onto the motor mount.
  37. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the blower wheel: adım 37, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the blower wheel: adım 37, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the blower wheel: adım 37, 3 resimden 3.
    • When you pry the blower wheel, try to apply pressure as close to the center of the wheel as possible.
    • Use a large flathead screwdriver or pry bar to pry the blower wheel off the motor axle.
  38. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 38, 1 resimden 1.
    • Remove the blower wheel.
    • During reassembly, push the blower wheel onto the axle until it touches the axle base.
  39. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement, Remove the motor mount: adım 39, 1 resimden 1.
    • Use a 1/2" (or 13 mm) socket to remove the four bolts securing the motor to its mount.
  40. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 40, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 40, 2 resimden 2.
    • Remove the motor mount from the motor.
  41. Karcher Rotary Floor Cleaner 17833080 2017 Drive Motor Replacement: adım 41, 1 resimden 1.
    • Only the motor remains.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arthur Shi
283.244 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.609 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 373
