Ana içeriğe geç
Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement
Neye ihtiyacın var
  1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the tank: adım 1, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the tank: adım 1, 2 resimden 2.
    • Before you begin, make sure to power off and unplug the device.
    • Lift the tank by the handle and remove it from the device.
  2. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: adım 2, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: adım 2, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: adım 2, 3 resimden 3.
    • Press the yellow button near each wheel base to release the wheels.
    • Remove both wheels from their sockets.
  3. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump cover: adım 3, 1 resimden 1.
    • Use a T20 driver to remove the three screws securing the pump cover.
  4. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 4, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 4, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 4, 3 resimden 3.
    • Remove the pump cover.
  5. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Disconnect the pump: adım 5, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Disconnect the pump: adım 5, 2 resimden 2.
    • Squeeze the middle plug by the edges and pull it out of its socket.
    • During reassembly, make sure that all plugs are firmly seated in their sockets.
  6. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: adım 6, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: adım 6, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: adım 6, 3 resimden 3.
    • Lift the pump assembly out of its recess.
    • Reassembly tip: make sure that the output hose end is fully secured to the housing socket.
  7. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 7, 3 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 7, 3 resimden 2. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 7, 3 resimden 3.
    • Peel the two rubber bearings away from the pump.
  8. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 8, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 8, 2 resimden 2.
    • Feed the pump plug through the rubber bushing's cutout.
  9. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 9, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 9, 2 resimden 2.
    • Pull the black check valve off the pump's output port.
  10. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 10, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: adım 10, 2 resimden 2.
    • Pull the clear hose off the pump's input port.
  11. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump: adım 11, 2 resimden 1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump: adım 11, 2 resimden 2.
    • Remove the pump.
    • Reassembly tip: be careful not to mix the pump's input and output. The arrow points towards the pump output, which should connect to the black check valve.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arthur Shi
283.767 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.669 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 676
