Giriş
Follow this guide to remove and replace the power switch module from the Karcher Vacuum Universal 14286230 2014.
Neye ihtiyacın var
The switch module should line up with the yellow plastic switch plunger.
The two plastic moulded discs line up using this black tab.
Unplug the wires from the switch. These are standard spade terminals that can be pulled apart.
Remove the switch.
Bir başkası bu kılavuzu tamamladı.
