Ana içeriğe geç
Katadyne Hiker Water Filter Cleaning
Neye ihtiyacın var
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: adım 1, 1 resimden 1.
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: adım 2, 1 resimden 1.
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: adım 3, 3 resimden 1. Katadyne Hiker Water Filter Cleaning: adım 3, 3 resimden 2. Katadyne Hiker Water Filter Cleaning: adım 3, 3 resimden 3.
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: adım 4, 3 resimden 1. Katadyne Hiker Water Filter Cleaning: adım 4, 3 resimden 2. Katadyne Hiker Water Filter Cleaning: adım 4, 3 resimden 3.
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: adım 5, 1 resimden 1.
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: adım 6, 1 resimden 1.
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: adım 7, 1 resimden 1.
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: adım 8, 2 resimden 1. Katadyne Hiker Water Filter Cleaning: adım 8, 2 resimden 2.
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
Sonuç
If difficulty pumping persists, a new filter is required.
Bir başkası bu kılavuzu tamamladı.
Dylan Carey
130 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G6
4 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 748
