Ana içeriğe geç
Kawasaki Ninja 300 Seat Replacement
Neye ihtiyacın var
  1. Kawasaki Ninja 300 Seat Replacement, Seat: adım 1, 3 resimden 1. Kawasaki Ninja 300 Seat Replacement, Seat: adım 1, 3 resimden 2. Kawasaki Ninja 300 Seat Replacement, Seat: adım 1, 3 resimden 3.
    • Locate the bolt holding the side seat cover in place and remove it using a 4mm hex key.
    • Make sure to also remove the bolt's washer.
  2. Kawasaki Ninja 300 Seat Replacement: adım 2, 3 resimden 1. Kawasaki Ninja 300 Seat Replacement: adım 2, 3 resimden 2. Kawasaki Ninja 300 Seat Replacement: adım 2, 3 resimden 3.
    • If you're working in cold conditions, be careful not to break the side seat cover.
    • Reach under the side seat cover and firmly pull it out to unseat it from its rubber clips. There is one at the rear of the cover and two at the front.
  3. Kawasaki Ninja 300 Seat Replacement: adım 3, 3 resimden 1. Kawasaki Ninja 300 Seat Replacement: adım 3, 3 resimden 2. Kawasaki Ninja 300 Seat Replacement: adım 3, 3 resimden 3.
    • Locate the seat bolt and remove it using a 5mm hex key.
    • It's best to use the longer end of the hex key, as the shorter end won't quite fit.
    • Repeat these steps on the other side of the motorcycle before continuing on to the next step.
  4. Kawasaki Ninja 300 Seat Replacement: adım 4, 3 resimden 1. Kawasaki Ninja 300 Seat Replacement: adım 4, 3 resimden 2. Kawasaki Ninja 300 Seat Replacement: adım 4, 3 resimden 3.
    • Grab the front section of the seat and slightly lift it up and back to remove it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
38.998 İtibar
82 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 53
Son 30 gün: 368
Her zaman: 13,849
