Ana içeriğe geç
Kayak Handle Replacement
Neye ihtiyacın var
    1. Kayak Handle Replacement, Handle: adım 1, 1 resimden 1.
      • Detach the handle and paracord strap from the kayak.
      FixBot'a Sor
      Yorum Ekle
    2. Kayak Handle Replacement: adım 2, 3 resimden 1. Kayak Handle Replacement: adım 2, 3 resimden 2. Kayak Handle Replacement: adım 2, 3 resimden 3.
      • Insert the screwdriver into the head of the bolt on the bottom side of the handle.
      • Apply pressure to the bottom of the handle.
      • Remove the top part of the handle by using the screwdriver to pop it out.
      • Caution: Do not let the hardware fall into the hull, as it may slide into unreachable areas of the bow or stern.
      FixBot'a Sor
      Yorum Ekle
    3. Kayak Handle Replacement: adım 3, 2 resimden 1. Kayak Handle Replacement: adım 3, 2 resimden 2.
      • Pull the paracord out of the handle so they are separate from each other.
      FixBot'a Sor
      Yorum Ekle
    4. Kayak Handle Replacement: adım 4, 3 resimden 1. Kayak Handle Replacement: adım 4, 3 resimden 2. Kayak Handle Replacement: adım 4, 3 resimden 3.
      • Cut the end of the paracord using your knife or a pair of scissors.
      • Insert the paracord into the bottom side of the handle through the small hole.
      • Pull it through so each side of the paracord is evenly inserted.
      FixBot'a Sor
      Yorum Ekle
    5. Kayak Handle Replacement: adım 5, 2 resimden 1. Kayak Handle Replacement: adım 5, 2 resimden 2.
      • Tie a knot with the paracord using both ends of the already inserted paracord.
      • Pull it tight and be sure that the knot is as close to the edge of the paracord as possible.
      • Cut the excess paracord at the end of the knot if there is any.
      FixBot'a Sor
      Yorum Ekle
    6. Kayak Handle Replacement: adım 6, 3 resimden 1. Kayak Handle Replacement: adım 6, 3 resimden 2. Kayak Handle Replacement: adım 6, 3 resimden 3.
      • Pull the paracord through the handle so that the knot is now inside the handle.
      • Add the cover of the handle back onto the top. Secure it down tightly.
      FixBot'a Sor
      Yorum Ekle
    7. Kayak Handle Replacement: adım 7, 3 resimden 1. Kayak Handle Replacement: adım 7, 3 resimden 2. Kayak Handle Replacement: adım 7, 3 resimden 3.
      • Locate the metal bar on the kayak and place the looped end of the new handle underneath it.
      • Pull the paracord all the way through until the handle stops it.
      • Loop the paracord over the plastic handle.
      • Pull the handle tightly to secure it in place.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 236
