Ana içeriğe geç
Kazoo Diaphragm Replacement
Neye ihtiyacın var
  1. Kazoo Diaphragm Replacement, Diaphragm: adım 1, 1 resimden 1.
    • Lay your kazoo down on a flat surface.
  2. Kazoo Diaphragm Replacement: adım 2, 2 resimden 1. Kazoo Diaphragm Replacement: adım 2, 2 resimden 2.
    • Untwist the cap in the middle of the kazoo and set it to the side.
  3. Kazoo Diaphragm Replacement: adım 3, 2 resimden 1. Kazoo Diaphragm Replacement: adım 3, 2 resimden 2.
    • Take the damaged diaphragm out with your fingers.
    • If you can't get the damaged diaphragm out with your fingers, turn the kazoo over and let the diaphragm fall out.
  4. Kazoo Diaphragm Replacement: adım 4, 2 resimden 1. Kazoo Diaphragm Replacement: adım 4, 2 resimden 2.
    • Take a new diaphragm and place it back into the kazoo.
    • Twist the cap back on.
    • If you don't have any kazoo diaphragms, use scissors to cut a plastic wrapper or baking paper to the size of the hole and use that instead.
  5. Kazoo Diaphragm Replacement: adım 5, 1 resimden 1.
    • Take some paper towel and spray isopropyl alcohol on it to wipe off any dirt or dust.
  6. Kazoo Diaphragm Replacement: adım 6, 1 resimden 1.
    • Finally, let the kazoo dry off for 5 minutes, and it will sound new again. Happy playing!
Sonuç
Jose Meza
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 31
Son 30 gün: 146
Her zaman: 3,597
