Ana içeriğe geç
KeepRite C9MPV075F12C1 Furnace Filter Replacement
Neye ihtiyacın var
  1. KeepRite C9MPV075F12C1 Furnace Filter Replacement, KeepRite C9MPV075F12C1 Furnace filter: adım 1, 2 resimden 1. KeepRite C9MPV075F12C1 Furnace Filter Replacement, KeepRite C9MPV075F12C1 Furnace filter: adım 1, 2 resimden 2.
    • Find the power switch labeled "Gas Furnace".
    • Flick the switch to the "off" position to turn off the furnace.
  2. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 2, 3 resimden 1. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 2, 3 resimden 2. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 2, 3 resimden 3.
    • Remove the filter found at the bottom part of the furnace in between the return duct and the blower motor.
    • Remove the furnace cover out of the slot by popping the cover off.
    • Remove the filter by sliding it out horizontally with your fingers.
    • The return duct will be hot to touch. Wait 5 to 10 minutes before you attempt to remove the existing filter.
  3. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 3, 2 resimden 1. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 3, 2 resimden 2.
    • Use the old filter to determine the filter size.
    • Look to the side of the filter and you will see the size labelled in inches.
    • The filter is read as "Length X width X depth", Some furnace filters may have two measurements. One is nominal size expressed in whole numbers and the other is the actual size which is in decimals.
  4. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 4, 3 resimden 1. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 4, 3 resimden 2. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 4, 3 resimden 3.
    • Look to the arrow written on the side of the new filter.
    • Slide the filter horizontally into the furnace according to where the arrow is facing to install the new filter.
    • Pop the cover back into the filter slot.
  5. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 5, 2 resimden 1. KeepRite C9MPV075F12C1 Furnace Filter Replacement: adım 5, 2 resimden 2.
    • Once the new filter is installed, find the power switch again and flick the switch to the "on" position.
Sonuç
Once these steps are followed you would have successfully replaced a furnace filter in a C9MPV075F12C1 KeepRite furnace.
Domenico Lasalandra
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 2,195
