Ana içeriğe geç
Kenmore 110 Series Washing Machine Drive Belt Replacement
Neye ihtiyacın var
  1. Kenmore 110 Series Washing Machine Drive Belt Replacement, Drive Belt: adım 1, 1 resimden 1.
    • To avoid risk of electric shock, unplug the washing machine.
    • Lay the washing machine on its back.
  2. Kenmore 110 Series Washing Machine Drive Belt Replacement: adım 2, 3 resimden 1. Kenmore 110 Series Washing Machine Drive Belt Replacement: adım 2, 3 resimden 2. Kenmore 110 Series Washing Machine Drive Belt Replacement: adım 2, 3 resimden 3.
    • Using a 5/16" socket wrench, remove both screws from the belt cover.
    • Remove the belt cover from the washer.
  3. Kenmore 110 Series Washing Machine Drive Belt Replacement: adım 3, 3 resimden 1. Kenmore 110 Series Washing Machine Drive Belt Replacement: adım 3, 3 resimden 2. Kenmore 110 Series Washing Machine Drive Belt Replacement: adım 3, 3 resimden 3.
    • Using a 1/2" socket, remove the bolt securing the drive pulley.
    • Remove the drive pulley and belt.
    • When installing a new belt, wrap the belt around both the motor and drive pulleys before reinstalling the drive pulley.
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Robert Trout
1.234 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G43
5 Üyeler
11 adet Kılavuz yazıldı
8 Yorum
What would be reason that rinse cycle doesn't spin and it leaks
lauraleahenquinette - Yanıt
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
Gary Long Jr - Yanıt
It makes noise like it’s working but it’s not grabbing anything
Ricardo Vallegos - Yanıt
You can change your gearbox
Adarsh Pandey -
What belt type should I use for a 110.24642300? I cannot find its belt online.
Elizabeth Glenski - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 163
Son 30 gün: 692
Her zaman: 121,037
