Ana içeriğe geç
Kenmore 110 Series Washing Machine Electronic Control Replacement
Neye ihtiyacın var
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: adım 1, 1 resimden 1.
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: adım 2, 3 resimden 1. Kenmore 110 Series Washing Machine Electronic Control Replacement: adım 2, 3 resimden 2. Kenmore 110 Series Washing Machine Electronic Control Replacement: adım 2, 3 resimden 3.
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: adım 3, 2 resimden 1. Kenmore 110 Series Washing Machine Electronic Control Replacement: adım 3, 2 resimden 2.
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Robert Trout
1.234 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G43
5 Üyeler
11 adet Kılavuz yazıldı
3 Yorum
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - Yanıt
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 30
Son 30 gün: 165
Her zaman: 28,034
