Giriş
Use this guide to replace a faulty water level sensor.
Neye ihtiyacın var
Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
Lifting from the rear, remove the top panel.
5 farklı kişi bu kılavuzu tamamladı.
4 Yorum
how to test water level switch??
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
