Ana içeriğe geç
Kenmore 110 Series Washing Machine Water Level Sensor Replacement
Neye ihtiyacın var
  1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement, Water Level Sensor: adım 1, 1 resimden 1.
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: adım 2, 3 resimden 1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: adım 2, 3 resimden 2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: adım 2, 3 resimden 3.
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: adım 3, 3 resimden 1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: adım 3, 3 resimden 2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: adım 3, 3 resimden 3.
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Robert Trout
1.234 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G43
5 Üyeler
11 adet Kılavuz yazıldı
4 Yorum
how to test water level switch??
countryrhoads4x4 - Yanıt
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Rod Brannon - Yanıt
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
Shannon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 36
Son 30 gün: 168
Her zaman: 39,835
