Ana içeriğe geç
Kenmore 110 Series Washing Machine Water Pump Replacement
Neye ihtiyacın var
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: adım 1, 1 resimden 1.
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: adım 2, 3 resimden 1. Kenmore 110 Series Washing Machine Water Pump Replacement: adım 2, 3 resimden 2. Kenmore 110 Series Washing Machine Water Pump Replacement: adım 2, 3 resimden 3.
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Robert Trout
1.234 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G43
5 Üyeler
11 adet Kılavuz yazıldı
9 Yorum
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Yanıt
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Yanıt
My clothes are still really wet.
Tracy Schultz - Yanıt
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 94
Son 30 gün: 347
Her zaman: 58,693
