Giriş
Electric clothing-washing machines have sensor switches about doors. A switch is a moving mechanical part. In Kenmore 80, this switch can wear-out, or its plastic screw bosses can break. Workspace: have room in front of your washing machine, enough space such that it could tip over forward so its front is on floor, in front of its present position.
Neye ihtiyacın var
Control panel console is fastened with two screws. Remove screws, pull bottom end of control panel forward (towards you), swing it upward, rest it in flipped position.
Press on tab to release clip/latch. Grip connector, not wires, and pull it off of fixed connector.
Use prise tool to remove two case clips. Pull top of case towards you, rock case (almost whole cabinet: case top, front, left & right) on its bottom front edge as axis, lower front of case until it rests on floor.
Case grounding wire is fastened on with one screw, 5/16 (five sixteenths) inch hexagon head. Unhook wires from the guide hooks.
Switch is fastened on with two screws.
Remove connector from case top, squeezing connector's panel mount tabs to free it. when replacing: Face connector with its wedge bump facing frontward.
4 farklı kişi bu kılavuzu tamamladı.
