Ana içeriğe geç
Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement
Neye ihtiyacın var
  1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: adım 1, 3 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: adım 1, 3 resimden 2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: adım 1, 3 resimden 3.
    • Unplug the washing machine.
    • Using a flat head screwdriver, gently wedge the end caps off of the control console in order to open it up.
  2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 2, 3 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 2, 3 resimden 2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 2, 3 resimden 3.
    • Lift and swing the console upward.
  3. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 3, 3 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 3, 3 resimden 2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 3, 3 resimden 3.
    • Unplug the lid-switch secured under the console.
  4. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 4, 3 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 4, 3 resimden 2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 4, 3 resimden 3.
    • Remove the console clips using a flat head screwdriver to release the chassis.
  5. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 5, 3 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 5, 3 resimden 2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 5, 3 resimden 3.
    • Stand in front of the washer and remove the chassis by lifting and pulling it towards you to expose the lower components.
  6. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 6, 2 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 6, 2 resimden 2.
    • Use the flat head screwdriver to flip the restraining clips and release the drain pump.
  7. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 7, 2 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 7, 2 resimden 2.
    • Remove the drive motor by unplugging the motor connector.
  8. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 8, 2 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 8, 2 resimden 2.
    • Remove connections to the capacitor.
  9. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 9, 3 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 9, 3 resimden 2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 9, 3 resimden 3.
    • Place the drive motor to the side and remove the direct drive coupler by sliding it off.
  10. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 10, 2 resimden 1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: adım 10, 2 resimden 2.
    • Replace with the new direct drive coupler and use the end of your screwdriver to seat it flush on the drive motor.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 86
Her zaman: 5,022
