Ana içeriğe geç
Kensington Hi-Fi Headphones 33137 Speaker Cover
  1. Kensington Hi-Fi Headphones 33137 Speaker Cover, Speaker Cover: adım 1, 3 resimden 1. Kensington Hi-Fi Headphones 33137 Speaker Cover, Speaker Cover: adım 1, 3 resimden 2. Kensington Hi-Fi Headphones 33137 Speaker Cover, Speaker Cover: adım 1, 3 resimden 3.
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Kensington Hi-Fi Headphones 33137 Speaker Cover: adım 2, 3 resimden 1. Kensington Hi-Fi Headphones 33137 Speaker Cover: adım 2, 3 resimden 2. Kensington Hi-Fi Headphones 33137 Speaker Cover: adım 2, 3 resimden 3.
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Kensington Hi-Fi Headphones 33137 Speaker Cover: adım 3, 3 resimden 1. Kensington Hi-Fi Headphones 33137 Speaker Cover: adım 3, 3 resimden 2. Kensington Hi-Fi Headphones 33137 Speaker Cover: adım 3, 3 resimden 3.
    • Hold the speaker cover in one hand and the speaker ear-padding in the other.
    • Turn the speaker cover counter-clockwise until it stops turning.
    • Pull the speaker cover and the speaker ear padding apart to expose the inner components of the speaker.
    • Make sure to pull the speakers apart gently to avoid disconnecting the speaker cable wires from the speaker.
    • If the speaker cover and ear-padding don't easily come apart, then make sure the speaker cover is fully turned.
    • Repeat this process for both speakers.
Sonuç
William Sanders
573 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-3, Benson Spring 2014 Clemson, Team 1-3, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G3
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 329
