Ana içeriğe geç
Kenwood CH250 Coupling Replacement
Neye ihtiyacın var
  1. Kenwood CH250 Coupling Replacement, Coupling: adım 1, 2 resimden 1. Kenwood CH250 Coupling Replacement, Coupling: adım 1, 2 resimden 2.
    • Remove the small cap covering the screw holding the coupling onto the shaft, using a small flat-head screw driver.
  2. Kenwood CH250 Coupling Replacement: adım 2, 1 resimden 1.
    • Unscrew the screw holding the coupling onto the shaft, using the PH1 screw driver.
  3. Kenwood CH250 Coupling Replacement: adım 3, 1 resimden 1.
    • Drag off the old coupling.
  4. Kenwood CH250 Coupling Replacement: adım 4, 1 resimden 1.
    • Clean any dirt around the shaft.
  5. Kenwood CH250 Coupling Replacement: adım 5, 2 resimden 1. Kenwood CH250 Coupling Replacement: adım 5, 2 resimden 2.
    • Put the plastic washer onto the shaft, then place the metal washer on top of the plastic washer.
    • Note: the old coupling did not have any washers.
  6. Kenwood CH250 Coupling Replacement: adım 6, 1 resimden 1.
    • Push the new coupling onto the shaft.
  7. Kenwood CH250 Coupling Replacement: adım 7, 1 resimden 1.
    • Secure the coupling with the screw, using the PH1 screw driver.
  8. Kenwood CH250 Coupling Replacement: adım 8, 1 resimden 1.
    • Finally, put the cap on top of the screw and press in place with the flat-head screw driver.
Bitiş Çizgisi
Sebastian Gassner
187 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 192
