Ana içeriğe geç
Kenwood Chef A701A Power Cable Replacement
Neye ihtiyacın var
  1. Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: adım 1, 2 resimden 1. Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: adım 1, 2 resimden 2.
    • Turn the mixer upside down
    • Remove the two screws holding the white cable grip.
    • Remove the black cable grip. The long screw also holds the cover onto the terminal block
  2. Kenwood Chef A701A Power Cable Replacement, Remove the old cable: adım 2, 1 resimden 1.
    • Remove the cable cover to expose the terminal block.
    • Remove the wires from the live and neutral terminals.
    • Thread the cables out though the cover and then from the mixer chassis
    • To refit simply follow the removal process in reverse
    • Be sure to connect the wires to the correct terminals, Brown - Live, Blue, Neutral.
    • If fitting a new plug ensure it is fitted with the appropriate fuse. If in any doubt consult a compitent electrician/electrical engineer
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Grant
143 İtibar
1 Kılavuz yazıldı
Bir Yorum
Important addition: make sure you leave enough cable length free under the mixer for when you raise the top of the mixer during use to change accessories or remove the bowl. Our local electrical repair shop didn’t think to do this and as soon as I raised the top the cable was pulled out.
Karen Leach - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 17
Son 30 gün: 65
Her zaman: 9,368
