Ana içeriğe geç
Kenwood DNX571HD GPS Antenna Connection Replacement
Neye ihtiyacın var
  1. Kenwood DNX571HD GPS Antenna Connection Replacement, CD/DVD Drive: adım 1, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement, CD/DVD Drive: adım 1, 2 resimden 2.
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
    FixBot'a Sor
  2. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 2, 3 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 2, 3 resimden 2. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 2, 3 resimden 3.
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
    FixBot'a Sor
  3. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 3, 1 resimden 1.
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
    FixBot'a Sor
  4. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 4, 3 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 4, 3 resimden 2. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 4, 3 resimden 3.
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
    FixBot'a Sor
  5. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 5, 1 resimden 1.
    • Lift the CD drive carefully to expose the attached cable underneath.
    FixBot'a Sor
  6. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 6, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 6, 2 resimden 2.
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
    FixBot'a Sor
  7. Kenwood DNX571HD GPS Antenna Connection Replacement, Cooling Fan: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully unplug the fan power cord with the tweezers.
    FixBot'a Sor
  8. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 8, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 8, 2 resimden 2.
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
    FixBot'a Sor
  9. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 9, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 9, 2 resimden 2.
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
    FixBot'a Sor
  10. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 10, 3 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 10, 3 resimden 2. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 10, 3 resimden 3.
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
    FixBot'a Sor
  11. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 11, 1 resimden 1.
    • Lift the top part of the unit up from the lower chassis.
    FixBot'a Sor
  12. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 12, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 12, 2 resimden 2.
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
    FixBot'a Sor
  13. Kenwood DNX571HD GPS Antenna Connection Replacement, GPS Antenna Connection: adım 13, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement, GPS Antenna Connection: adım 13, 2 resimden 2.
    • Using a spudger, undo the clasp to disconnect the large white ribbon cable.
    FixBot'a Sor
  14. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 14, 1 resimden 1.
    • Remove the 5mm screw with teeth from the casing with a Phillips #1 screwdriver.
    FixBot'a Sor
  15. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 15, 1 resimden 1.
    • Remove the four 5mm screws with a Phillips #1 screwdriver.
    FixBot'a Sor
  16. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 16, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 16, 2 resimden 2.
    • Remove the 5.5mm screw from the HDMI cable cover using a Phillips #2 screwdriver.
    FixBot'a Sor
  17. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 17, 1 resimden 1.
    • Remove the 5mm screw with a Phillips #1 screwdriver.
    FixBot'a Sor
  18. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 18, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 18, 2 resimden 2.
    • Remove the two 5.5mm screws from the back.
    • Lift the upper portion of the stereo free from the chassis.
    FixBot'a Sor
  19. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 19, 2 resimden 1. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 19, 2 resimden 2.
    • Remove the two screws underneath the GPS connector.
    • Desolder the GPS connector.
    • The GPS antenna is a thru-hole-mounted device. You must apply heat to each soldered pin individually and pull them out of the holes while the solder is molten.
    • The solder material, pins, and any surrounding material will get VERY hot while melting the connections. Do not touch any metal parts during the desoldering process and give the device time to cool off once you’re finished. It may also be good to take breaks so that the electronics aren’t kept hot for extended periods of time.
    FixBot'a Sor
  20. Kenwood DNX571HD GPS Antenna Connection Replacement: adım 20, 1 resimden 1.
    • To remove and reinsert the connector, on the top side of the board, use your finger to gently lift the metal plate to get enough clearance.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wendy Zaballos
976 İtibar
6 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 1,247
